The Ford Barn
-   -   Horn button rod length (https://www.fordbarn.com/forum/showthread.php?t=120998)
txturbo 10-22-2013 10:45 AM
Ready to order some parts for my steering column. But I see there are 3 different lengths for 30/31s. Neither of my steering columns has a horn button rod installed so I don't know what length I need. My replacement column has the shaft....I'm assuming I can measure this daft to determine which goth button assembly I need to order. The question is.... Where do I measure to and can it be done without completely disassembling the steering box?
700rpm 10-22-2013 11:25 AM
Re: Horn button rod length
Better to look at the chart in Bratton's catalog. It shows which ones are correct for which columns. It might be on their web site too.
txturbo 10-22-2013 12:04 PM
That's what I was looking at...it just lists them by length....but I don't have and old one to measure.
barnstuf 10-22-2013 12:05 PM
Yes there are three different lengths shown in the catalogs for 1930, but most 1930 vehicles and all 1931 use the 45 31/32 rod (A3616-H). The demand for the other two rods is very small.
txturbo 10-22-2013 12:11 PM
Thanks......the column I'm using for a replacement could be anything ....I don't know what year it is.
Bob C 10-22-2013 12:15 PM
If you look it also lists the length of the steering column tube and the shaft for
the two tooth gears.
Bob
txturbo 10-22-2013 12:18 PM
Bob
Ahhhh....ok...I didn't see that viewing it on my phone. I'll have to look at it again....thanks
Skrain 10-22-2013 12:19 PM
I think Mike's catalog shows the different ones, and shows where to measure them.
txturbo 10-22-2013 12:26 PM
I just looked again and I don't see any other info like that in the Bratton online catalog.
Skrain 10-22-2013 12:41 PM
That rod is actually for the light switch as well. Maybe it's listed under that classification...
txturbo 10-22-2013 12:49 PM
Good point...,.ill check
