Pennies in block Hi All,
I picked up an 8RT commercial motor to rebuild and I came across something interesting I wanted to run by you guys. I was out cleaning the gunk off the intake manifold surface trying to determine the year of manufacture and I noticed someone had pressed some pennies into the intake manifold seating area. http://farm6.staticflickr.com/5470/9...b682836c16.jpg 2013-09-08 17.12.12 by louisfbrooks, on Flickr http://farm4.staticflickr.com/3698/9...f8946e646e.jpg 2013-09-08 17.12.17 by louisfbrooks, on Flickr Any ideas why this was done? Will it be an issue with the rebuild? Block passes the visual inspection otherwise. It has been rebuilt in the past with stock parts and a small overbore. Hoping to rebuild it for a future AV8 project. There was no date code on the block, just the number 8 in a square stamped into the surface. But it looks to be red originally which I think means a '50-'51 block. Came apart real easy with none of the horror stories I have read about on here. Now I need to hold my breath and send it off to be cleaned and magnafluxed. Thanks, --louis |
Re: Pennies in block |
Re: Pennies in block The pennies are used to block the exhaust heat risers to the intake manifold. The thinking is to make a cooler intake and a denser fuel charge. Anymore they are used to make the exhaust bark louder. It really works. Knock them out to return to stock, no problem.
If you wish to reinstall them after the rebuild, make sure they are the older copper pennies, the newer zinc enriched pennies will melt. |
Re: Pennies in block Thanks guys. So much to learn about these cool little motors. Pennies look to be a '57 & '61 so I think I will keep them for the rebuild.
--louis |
Re: Pennies in block Quote:
Re: Pennies in block welcome to the 'Barn....have fun with flatheads...lol....Mike
--louis |
Re: Pennies in block I would drill an 1/8" hole in both of them to get a little heat under the carb.Other wise it will run crappy till fully warmed up. OMO ken ct.
Oh, yes... 1957 was a verry good year! |
Yeah I noticed that as well and will do when it gets rebuilt. As for '57 being a good year I will have to take your word for it. I wasn't born for another 15 years. ;) Thanks, --louis |
Re: Pennies in block What ever you say youngun.i graduated HS 15 yrs before you were born. Do what ever you think is right. ken ct.
Re: Pennies in block Using the pennies will reduce your gas mileage.
Re: Pennies in block The pennies popped out easy enough using a piece of 3/8 rod though the exhaust port. I will give some more thought to if they go back in or not. Thanks to everyone for their input.
Thanks, --louis |
Re: Pennies in block Welcome to the Barn.
Re: Pennies in block Good luck Louis. Just my 2 cents :D:D
Thanks, --louis |
Re: Pennies in block My Dad used to tell me...back in his day they used to match the year of the penny with the car for " Good luck"... strange why they would want the exhaust to pop in a commercial motor though? A Hot rodder that was a truck driver too I guess?
Randy |
--louis |
Re: Pennies in block welcome to the barn Louis,i,m pretty new to it ,around march when I imported my 51 fi truck to the u.k and had lots of problems I didn't know the answer to,along with my 39 coupe all questions have been answered and all the problems sorted ,at first I was reluctant to ask certain questions as I thought the answers are probably so obvious and I would feel little small asking them but all questions answered with knowledge and sometimes some humour which I like , good luck, regards jim.
