The Ford Barn
-   -   Question about Intake & Exhaust Manifold Gasket (https://www.fordbarn.com/forum/showthread.php?t=115399)
LizardsA 08-23-2013 10:45 AM
Good day all,
I have a question about the intake & exhaust manifold gasket(flat steel clad asbestos-like 1-piece gasket) for a 1930 Sport Coupe - which way round does the gasket go? In other words, steel surface facing the block or the manifold?
Kind regards
Mike
Purdy Swoft 08-23-2013 11:17 AM
Re: Question about Intake & Exhaust Manifold Gasket
Steel side facing the manifolds is correct.
LizardsA 08-23-2013 01:52 PM
Thanks Purdy, much obliged. Steel side away from the block, if I am correct?
Tom Wesenberg 08-23-2013 08:09 PM
Yes, as Purdy said the steel faces the manifold because the manifold is much hotter than the block.
LizardsA 08-24-2013 08:48 AM
Thanks guys, I assembled the manifold as you suggest, and the car runs much better now. Thanks for the advice
Purdy Swoft 08-24-2013 12:47 PM
Thanks for the feedback. Glad its running better!!
