side mtg tire on 1930 cabriolet grommet Hello I am a newbie to this site just used it a couple of times and had great help! I all most feel bad about asking this but I have tried a couple of times to put a new grommet in the splash shield where the spare tire mounts.
Do you need to heat the grommet in water or need 6 hands to do this job? |
Re: side mtg tire on 1930 cabriolet grommet Both
Re: side mtg tire on 1930 cabriolet grommet I don't remember for sure, but I'll bet when I did one for a friend I used Vaseline.
Re: side mtg tire on 1930 cabriolet grommet Try using a bit of brake fluid for lube. It won't attack the rubber either.
Re: side mtg tire on 1930 cabriolet grommet Quote:
Re: side mtg tire on 1930 cabriolet grommet Use Ruglyde rubber lubricant. I have a can that has the Ford logo on it. I also have used silicone lubricant.
Re: side mtg tire on 1930 cabriolet grommet thanks to all will try what ever works
Re: side mtg tire on 1930 cabriolet grommet You can slice the gromment to make it easier to install.
MIKE :) |
