The Ford Barn
-   -   sealing the steering wheel (https://www.fordbarn.com/forum/showthread.php?t=111232)
Patrick L. 07-08-2013 08:43 AM
These %$&^ steering wheels, again not one of Fords better ideas. Has anyone found a good way of sealing these things ?
I clean mine quite often, at least once a week. This morning it rained during our little coffee clutch and I rarely have the top up. As soon as I got in I noticed my hands were as black as coal along with a favorite shirt [ for some strange reason the belly keeps getting bigger]. I wiped down the wheel trying to dry it with a towel to keep from making things worse. The towel is now black, but thats fine as long as no more clothes were ruined. Just had to rant.
Mike 07-08-2013 08:50 AM
Re: sealing the steering wheel
I clear coated my steering wheel.
mike
29ModelA 07-08-2013 08:56 AM
I painted mine with some of that Fusion paint but I had filled nicks and things with epoxy. It has held up well for 300 miles so far.
If it was a nice original I might try clearing it.
eagle 07-08-2013 09:06 AM
My steering wheel is a nice original. It doesn't sound like its anything as bad as yours but it does make my hands a little black sometimes. I use a wet-wipe on it periodically to keep it clean, seems to work as good as anything.
Fred 07-08-2013 09:25 AM
The original RED one does the same or worse !!
gilitos 07-08-2013 09:36 AM
Mine always blackens my hands in wet weather. I figure it's deteriorating plastic that's dissolving off.
Tom Wesenberg 07-08-2013 09:57 AM
I think cleaning the wheel well, then spaying on a coat of semi-clear laquer would be the surest way to stop the rubbing off.
I wonder if rubbing in a coat of good car wax would do the trick?
Paul in Colorado 07-08-2013 03:49 PM
I use a leather steering wheel cover from Wheelskins. They cost more, but look and feel nice. My hands stay clean.
Paul
Patrick L. 07-08-2013 04:22 PM
OK, thanks. I was waiting until the body work/paint to re-do the wheel. That rain made a mess of things. I need to do something.
GordonJ 07-08-2013 11:24 PM
One quick recommendation for you that seemed to help my 29 steering wheel. Try coating it with a good quality hand lotion - stuff your wife says is expensive. [I think I used Aveena?] The first time will take numerous applications before it stops turning your rags black, but it seems to seal the wheel, especially in humid weather. And...it is easy to reapply if it dries out.
