The Ford Barn
-   -   steering boxes (https://www.fordbarn.com/forum/showthread.php?t=106813)
mrtexas 05-21-2013 08:45 PM
steering boxes
What year are these?
http://fordbarn.com/forum/picture.ph...ictureid=20933
woodypecker 05-21-2013 09:18 PM
Re: steering boxes
My eyes must be getting worse I can not see them.
mrtexas 05-21-2013 10:54 PM
Re: steering boxes
http://mrtexascitrus.weebly.com/steeringboxes.html
Karl Wolf 05-22-2013 12:43 AM
Re: steering boxes
They look like F100 truck, 53-56 (?) They are not F1...
Karl
Robert Dip 05-22-2013 07:00 AM
Re: steering boxes
As Karl Wolf mentioned, they are the later pick-up boxes. I prefer the earlier ones that have a longer sector protruding out of the frame, gives more clearance when adding the wedge plate on tapered frames like the '32 - '34's. It also has a large nut and lock washer for the pitman arm...giving one a lot more choices when fitting. Great boxes....Robert
Andy 05-22-2013 08:57 AM
Re: steering boxes
They are two different boxes. One is from a pick up and one is from a heavy truck. Both are F-100 era boxes. I am in the process of conveting a pick up box for use in a 32. I cut the mounting flange off and have made a new one to match the 32 frame. There is a lot of info on this on the HAMB. I have made a weld jig off a 32 box so I get everything positioned corrrectly.
