Generator question Generator quit working so removed it to the bench. All brushes worn down so that the brush holders were rubbing on the armature. No new brushes available on Saturday, so elongated the brush holes, shimmed the top of the brushes with tape, reinstalled generator and it now charges fine. For fun I connected a voltmeter to generator post on generator side of the cut out. At idle it read seven volts. wheneverer I reved up the motor the voltmeter would read zero. Slow down to idle and voltmeter would jump back up to seven volts. Repeated it several times. Clamped voltmeter lead under generator post nut to ensure good connection and bolted other lead to clean ground. Repeated several times again and same result. Drove a hundred miles Sunday and generator was charging strong. Why the voltage drop to zero at speeds above idle? I can't figure it out!
Re: Generator question Do you have a picture of the generator? The model A generator brushes should have slots, not holes, so there is no need to elongate them to slide them out for a bit more use. Also the Model A brush holders should have stops to prevent them from contacting the commutator when the brush is worn out.
Did you use an analog meter, or a digital meter? |
Re: Generator question Quote:
Re: Generator question Do you have some pictures of the brushes and commutator?
Also a picture of the regulator? |
