The Ford Barn
-   -   1948 Ford Ignition Housing Washer (https://www.fordbarn.com/forum/showthread.php?t=106490)
Blase 05-18-2013 11:01 AM
Wanted 1948 Ford Ignition Switch Housing Washer (Washer is Waverly to keep the housing tight for when you add the Ignition Bezel on.
Kurt in NJ 05-18-2013 12:23 PM
Re: 1948 Ford Ignition Housing Washer
A long time ago I patched together a 48 about the same time i parted out a 65 mustang ---the mustang ign switch fit the hole, probably many Fords used the same mounting between those years
