The Ford Barn
-   -   Sticky valves Just quit (https://www.fordbarn.com/forum/showthread.php?t=104771)
josh1331 04-29-2013 07:17 PM
Took car out to free up valves. One quarter mile later engine stopped. Stuck on road. Mmo in gas didn't get za chance to work. Towed home. One other thing. I found that new distributor caps and bodied are not good. The rotor contact was hitting two of the contacts in the distributor body portion. Josh
H. L. Chauvin 04-29-2013 08:13 PM
Re: Sticky valves Just quit
Humkble opinion:
From your details, it sounds more like you have a possibe electrical problem or something else besides a valve problem -- valves "usually" loosen up & get better with an engine running in lieu of getting worse.
BILL WILLIAMSON 04-29-2013 08:30 PM
Agree with H.L, you gotta' get the distributor proper & maybe that's the only problem. If you can afford it, why not get a quality rebuilt or a new "STOCK" re-pro & it will give you years of trouble free service. Bill W.
ford3 04-29-2013 08:35 PM
my guess is you ran out of gas, or pluged fuel system, filter, gas line or plugged needle and seat, or a bad coil or condensor, does a spark plug fire when you turn engine over, any gas to carb
Tom Wesenberg 04-29-2013 08:41 PM
I've seen caps and rotors as you described. I've bought the body and rotors from Bratton's, Bert's, Little Dearborn, and Snyder's and haven't had a problem with any of these. I install the new parts, then hand crank and watch the rotor to make sure it clears all 4 contacts.
Chuck Sea/Tac 04-30-2013 12:09 AM
Rotor to cap clearance is .025" and you want them all the same for smooth running
