The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   Dual exhaust manifolds (https://www.fordbarn.com/forum/showthread.php?t=104251)
sprink88 04-24-2013 06:52 AM
I have a 292 Y block
I see a guy on Craigslist who has a set of manifolds for $80. Used to be $100. They look brand new. Is this a good price? My new engine I am putting in has the ears cracked on mine. But I have my old manifolds which are in good shape. I would just like to sell those with the engine.
Also I notice a lot of them have the aluminum color paint in them. Where do I get that? These are not painted. However would the heat just burn off no matter what the paint?
Ole Don 04-24-2013 08:16 AM
Re: Dual exhaust manifolds
$80.00 is an OK price for the good manifolds, but not great. There are more than one type. The good ones are flat on top. They flow very well for that CI size. If you clean the manifold very well, hang it up and spray it with VHT exhaust paint. Only enough paint to cover so it wont crack and peel. If you have a truck, you could use the rams horns, They flow better than passenger headers. Factory bolt torque is amazingly low. The factory used flat washers and the bolts are like 12 to 15 Ft. Lbs to prevent broken ears
sprink88 04-24-2013 08:27 AM
Thank you. I have heard that about the ram horns. But this will be going in a 57 Fairlane 500.
I was thinking $80 isn't horrible either. BUT $60 is a lot better! I will try to post a pic of them. They look really clean. As in new clean.
sprink88 04-24-2013 08:33 AM
2 Attachment(s)
this is what they look like. and like i said... they're clean looking.
Tinker 04-24-2013 09:09 AM
Offer him $60 for them and see what happens. Or $70, Hey if you bought a pair from someone that is not local to you, you'd have to pay shipping. That could cost a bit based on the weight of the manifolds and packing supplies.
sprink88 04-24-2013 09:40 AM
Very true. I like these because they are so clean. I am sure I could get them cheaper from the all ford junkyard close to me
sprink88 04-24-2013 09:41 AM
Btw. Have ram horns been tried with success on a car? Or is it not even worth the bother.
Y-Blockhead 04-24-2013 10:57 AM
Won't work, they dump out right where your motor mounts want to be...:eek:
sprink88 04-24-2013 04:14 PM
ARG! That is what I figured
34pickup 04-24-2013 07:49 PM
I just tried to sell a set off of a 57 312 at autofair in Charlotte for 50 bucks but could only get 25 dollars for them and they were in good condition, all cleaned up and painted. Don't pay too much, they aren't that hard to find.
paul2748 04-24-2013 08:43 PM
For coating, I use Hi Temp Cast Blast. It has lasted three years now without problems. You must sandblast them.
sprink88 04-25-2013 06:57 AM
@Paul2748 Even though they are that clean? For sandblasting?
Ole Don 04-25-2013 07:58 AM
On the new ones, try hanging them up and washing down with acetone or lacquer thinner before paint. Let air dry and blow off. The factory used no gaskets here, but most gasket sets now include very nice easy to use gaskets. If you spray the soft side with WD 40, they can be re-used.
sprink88 04-25-2013 09:07 PM
Thanks Ole Don for the info!!
junkyardjeff 04-30-2013 09:43 PM
If those manifolds are 57 and up grab them as I have seen people asking up to 200 for them,I have less then 60 in the pair I have but got then one at a time. Even if the manifolds are 55/6 80 is not too bad as I have seen some asking around 125 for a pair of them and they were not cleaned up.
paul2748 05-01-2013 09:45 PM
If they don't have any rust on them, then you don't need blasting.
