windshield filler trim help help is the filler trim at the bottom of the windshield the same on a model a truck as on a model a coupe need to know thanks
Re: windshield filler trim help They are the same.
Re: windshield filler trim help thanks for the info
Re: windshield filler trim help Not sure exactly what you're referring to, but I think the answer is likely no. There was a discussion about a month ago, see link below:
http://fordbarn.com/forum/showthread.php?t=101016 |
Re: windshield filler trim help im talking about the one on the outside of the car underneath the windshield
Re: windshield filler trim help So you are referring to the piece that has a number of large holes in it - correct? I am not sure they are the same, but they could be as trucks, coupes, and tudors use the same gas tank. The A pillars are different between a truck and coupes/tudors, so it is possible they are not the same. The best thing would be to find a truck and coup/tudor and measure the filler strip length and ends. I have both and I could check tomorrow and see if I can tell whether they are the same of different.
Rusty Nelson |
