1928 column length 1 Attachment(s)
Anyone know the length of the column tube for a 1928 Tudor. Mine has been modified with a vega box and I want to make sure the tube/housing hasn't been shortened.
I need the measurement from the bottom of the rod lip to the pitman shaft centerline. |
Re: 1928 column length I just measured my spare 7 tooth column and it's 11 1/2".
Re: 1928 column length Thank you very much.
