The Ford Barn
-   -   Simmons Side Bowl Carburetor Connector (https://www.fordbarn.com/forum/showthread.php?t=100801)
Joop 03-19-2013 10:04 AM
3 Attachment(s)
I need some help locating this Simmons Carburetor Side Bowl connector.
Can someone send me in the right direction.
Thanks.
Joe K 03-19-2013 10:25 AM
Re: Simmons Side Bowl Carburetor Connector
Well, that's a little different. Do you own this and having problems, or simply trying to find the part to replace the one you don't have?
Joe K
Joop 03-19-2013 12:03 PM
I do not have these but need it to make my restoration authentic
I am still looking for the bowl also, see the wanted page.
Joe K 03-19-2013 12:37 PM
Gosh. One might wonder if the Simmons part was anything like the Ford sidebowl part? Here's Snyder's pix.
http://www.snydersantiqueauto.com/up...9161-10447.jpg
I believe what you're looking at is the side towards the carburetor bowl. The silver threaded part you see is the connector bolt which is hollow and shows as a hex on the other side.
I think this one takes the "Ford Nut" (as said by another respondant) i.e. a compression nut and ferrule. So in this much it's probably not exact. Do you need exact?
Joe K
Joe K 03-19-2013 01:11 PM
Link to your want. https://www.fordbarn.com/forum/showthread.php?t=98216
And the Snyder repop is not exact.
Joe K
Joop 03-21-2013 10:38 AM
Check out my want ad Joe, the Simmons side bowl is different internally.
I am sure the Zenith will work but prefer the original Simmons.
Joe K 03-21-2013 10:56 AM
MOds figure this out. Joop's reply No. 6 used to come before my final No. 5. Somehow/somewhere this thread got date modified.
Joe K
CarlG 03-21-2013 11:04 AM
Doesn't the International Date Line run down the Mississippi river? :D
Joop 03-25-2013 03:42 PM
maybe?
