Repro rearview mirror from Mike's is spot on. Just received the repro rearview mirror for the Tudor from Mike's A-Fordable. It is very difficult to tell it apart from the original! The repro glass is smoother (the original has the slightest hint of "waviness" to the glass), and just barely thicker than the original, but the edge and color and reflectability are exactly the same. Wow!
Nice to see reproduction parts that are actual reproductions, and not just barely "good enough". Well done, Mike! |
Re: Repro rearview mirror from Mike's is spot on. Quote:
Re: Repro rearview mirror from Mike's is spot on. 1 Attachment(s)
I should have actually said "just barely wider". Poor choice of words. The thickness of the original is 0.022" and the repro is 0.021". The repro is about 1/8" wider.
Re: Repro rearview mirror from Mike's is spot on. I see what you are saying, it is a far better part than alot of the "reproduction" parts made. If the mirror size is truly the only thing wrong, as compared to an original, is the size of the glass maybe a call to Mike's can get the manufacturer to decrease the size?
Re: Repro rearview mirror from Mike's is spot on. The repro is a tad narrower, so the call should be to increase the width slightly is all. The edge detail is absolutely perfect.
