32 Coupe with F-100 steering conversion 6 Attachment(s)
I finally finished my conversion to a F-100 steering box. I had an earlier thread but it got into a discusion about brazing. The box went in with no problems at all. All the holes lined up and the flange fit the frame perfectly. It actually fits better than the stock box. I have more header clearance. The column drop had to move in about 1/8" is all. I am delighted with the way it drives. It used to be hard to come back if it started to get to the side of a crowned road. No more. The light switch works and the column lock works. Now on to the 3.25 rear end project. Then the Lincoln brakes and then the 12V conversion.
Re: 32 Coupe with F-100 steering conversion Nice work and it looks good!
Re: 32 Coupe with F-100 steering conversion Very nice job, we sell a lot of model A F100 conversions,and a few 32/34 kits.you went the right way with the model A sq. sector shaft. modelaonly.net
Re: 32 Coupe with F-100 steering conversion Very nice work Andy.
Re: 32 Coupe with F-100 steering conversion Nice work, Andy, a very neat, unobtrusive job that gives a real world benefit to the driving experience.
Mart. |
Re: 32 Coupe with F-100 steering conversion Looks good!
Why did you use a model a steering arm? |
Re: 32 Coupe with F-100 steering conversion The A arm allowed me to leave the frame unmodified. The stock F100 arm is bulky and would not clear the stock 32 flange bolts. The shaft is also too big in diameter. Cutting the shaft square also reduced it so it will go thru the stock frame hole and the A arm clears the bolts. I wanted to not cut anything on the car. I can put the ginnie box back in and nobody can ever tell it was different.
Re: 32 Coupe with F-100 steering conversion Great work. Looks as good or better than the secret method that noone would post pictures of for several years.
Re: 32 Coupe with F-100 steering conversion Thanks for all the nice comments!! It looks so stock I doubt few will recognize it is not stock.
Re: 32 Coupe with F-100 steering conversion Yeah that makes sense!
Good soloution |
Re: 32 Coupe with F-100 steering conversion What type of HEADER are you using??
Re: 32 Coupe with F-100 steering conversion The headers are the cheap ones from Speedway. The only problem was the tube by the steering box. I tried a couple of ideas but ended up tight and back and down. With the F100 box, there might be room for a forward and up route. That would better follow the direction of the port.
I used a right side stock manifold for a weld jig |
Re: 32 Coupe with F-100 steering conversion What is the length of the pitman arm [ hole center to center] and the number of wheel turns lock to lock?
Re: 32 Coupe with F-100 steering conversion The arm is stock 32 length. 5 1/2"
The box is 18 to 1 but hits the spindle stops both ways. I have 3 3/4 turns. The box will turn 4 1/2. I might try a shorter arm. The Model A arm was shortened and a bung welded on instead of the ball. |
Re: 32 Coupe with F-100 steering conversion Hey Andy,
Nice pics and nice job ! I also put an F100 on my A roadster. Best improvement for the $ ! |
Re: 32 Coupe with F-100 steering conversion Andy,
Is there more or less clearance on the header by the box with the F100 parts? Thanks Jim |
Re: 32 Coupe with F-100 steering conversion I have more clearance. The shaft is at the same distance in from the frame but the box is smaller on the wheel end. It has the big bearing at the bottom so the top is less bulky. I had to use header bolts before but it looks like I can use std bolts now. They were sure easier to put in.
I put on a new flange so the box is closer to the frame than if I had used the wedge. |
Re: 32 Coupe with F-100 steering conversion Quote:
Thanks for the reply. |
Re: 32 Coupe with F-100 steering conversion Nice! Don't know how I missed this thread when it first came out. Thanks Andy!
Re: 32 Coupe with F-100 steering conversion What year is the F100 box?
