column drop parts City:
boonville
State:
nc
I have a 1939 or 1940 column drop and Im missing the lock leaver and parts. I have a pictured attached to the forum with what I have. If anyone hase parts for this please let me know. Thanks
Billy http://www.jalopyjournal.com/forum/p...ctureid=329728 |
Re: column drop parts Btt
Re: column drop parts Billy, I have most everything missing but the actual lever. I am also missing a small spring and a ball that go in the detent. Also two screws that hold the electrical stuff to the back of the part. All should be easy enough to get at a hardwear store except the lever. I can spec the stuff out. The cap that goes on the end of the plunger needs replating and the plunger assy has some buggered splines but all is doable. The plunger assy could use a pin replaced also. $30 shipped
Re: column drop parts BILLIE-BOB; There is a world of difference, between 39 / 40 column drop. the 39 is soild in the center,is where the flag swithch is .... now the 40 is open in the center,where the shift shaft goes through for the column shift trans your ( three on the tree ) thingie, sounds like Andy has what you need, I hope..... now I need a bumper brace for 39 deluxe, frount, short center one, comes out from the frame and curls toward the center? any help. thanks ...OLD....BILL
