31 slant windshield crank How long is the side window crank on a slant windshield cab?
Re: 31 slant windshield crank I can get you exact when I get to them later
But the correct is about 3 1/2” There’s longer ones that were used in later models about 4 1/2”+ estimating from Memory A lot use the longer if not showing because of more leverage on the wind up and down |
Re: 31 slant windshield crank I think we should ask that your are talking about the handle you crank inside the car?
Or the levers that raise the window in the door? |
Re: 31 slant windshield crank The inside crank
