Headlight Bar I found a headlight bar on the internet that was listed as a Model A bar. It had oval mounting holes. All of the Model A bars that I have seen have square mounting holes. I have seen 1932 bars and bolts that have oval mounting shaped attachment. Is that the only difference in the two models? Any input would be appreciated.
Re: Headlight Bar Without a picture it is hard to identify, but in early 30 they made a stamped steel headlight bar that had slots for the bolts for where the license plate attaches. Is this what you were referring to?
Re: Headlight Bar If it is a '32 bar there will be bosses around the oval holes, it won't sit flat on a surface like an A bar. I read some were that the BB truck bars are plain, no stainless between the sockets. Bob
Re: Headlight Bar 1 Attachment(s)
Here are the three bars that he has.
Re: Headlight Bar I have an original 32 Hdlmp Bar , it doe's have oval bolt holes at the fender mounts. in your picture it appears to have a 30/31 Bar at the top.....Center is a 32 Bar.....Lower bar is 28/29
Re: Headlight Bar Quote:
