Model b coolant level indicator 3 Attachment(s)
Some time back I opened a thread on Model B coolant level.
Rather than guessing where the coolant was and continually topping up after a run; I made up this arrangement. Remove the rear water pump bolt and fit various items made up on a winters' evening Essential that the sight tube is able to vent back in to the top of the radiator ! As long as you know the coolant is above the top of the pump you're up and running.:):):) |
Re: Model b coolant level indicator Very nice, great idea and excellent craftsmanship! Thanks for posting:D
Keep 4-banging! |
Re: Model b coolant level indicator 6 Attachment(s)
Jerseyboy....thank you!:)....didn't think much of the cheap pressed out exhaust deflectors......so 35 hours later.
Just a matter of time:):):) |
