aluminuminging engine? Ok, I've read what's available in our past files regarding 'claying' for head/piston clearances. Also, regarding aluminum ball use method. Indications are that I've got a serious clearance problem. I have aluminum, but do not know if a guy makes alum balls or buys such ? And , what SIZE are the balls make; how are they used..placement; kept in place..what ?
Re: aluminuminging engine? Aluminum might be a bit hard.. I would stay with clay or possibly soft solder. then Size really doesn't matter.
Re: aluminuminging engine? Roll kitchen aluminum foil into little balls but not so tight that they won't collapse.
Re: aluminuminging engine? Quote:
Re: aluminuminging engine? They're held in place with a dab of grease.
Real hotrodder's use Butch Wax though! |
Re: aluminuminging engine? Thanks to ALL,
I feel confident now in trying/using this method. I also read in the files that someone suggested and uses 'body putty', as it hardens when left set....therefore, 'easier' to measure ! Any comments pos/neg on this method ? Finally, my hands 'shakes a bit' and I have problems seeing what's shaking:) . Is there a mike instrument that you would recommend, that would be easier to use/see...mabe something digital with large numbers ? |
Re: aluminuminging engine? Only: $29.99
Sale: $19.99 http://www.harborfreight.com/media/c...mage_13305.jpg Harbor freight under $20.00 6" Digital Caliper with Metric and SAE Fractional Readings Item #68304 |
Re: aluminuminging engine? I used to buy modeling clay at a hobby store for few bucks.
Pretty sticky so A little talcum powder helps to avoid it sticking to the head. Peel and measure with caliper. |
Re: aluminuminging engine? ......And hope the dimension doesn't change during the peeling process!
