rear end noise I am working on a model a rear end . If I turn the drive shaft back and forth there is a clonk. Any ideas on what this maybe ? steve
Re: rear end noise If the drums are still on pull them off and check to see if brakes are hanging up. If there is a clunk and drums are off, time to pull and look inside.
Re: rear end noise if there is no lubricant on the gears and backlash is on the high side it could just be the pinion tooth contacting the ring gear tooth
Re: rear end noise drums and backing plates are off, no lube in rear, no broken teeth. Inside looks O.K. ????
Re: rear end noise Does this have anything to do with eating baked beans? (Grin)
Re: rear end noise ...
Re: rear end noise Is this a fresh rebuild? If it's not, even drained there would or should be still some lube on the gears etc. How do you know the insides look ok? You cant see that much thru the fill hole. If a fresh rebuild, set to18- 20 INCH POUNDS preload, there might be a tick because there is some drag, but not a clonk.
Re: rear end noise Quote:
Re: rear end noise Just a smidge , back and forth. Took this apart and cleaned everything.
Re: rear end noise I put it on the bench and began to inspect (when it was together) It had a little the play back and forth. From there I drain the oil ,very little in it,took it apart and inspected the internals. Everything looked good even wear on ring and pinion.that is where I am at this point. steve
Re: rear end noise Steve, If you have the original gaskets you can measure them with a caliper for reference noting what thickness was in what side, however , I would reset the preload using new gaskets anyway. It could have been off. You should have about .005 backlash on the pinion.
You will have to remove the pinion and driveshaft to set the bearing preload first before setting he tooth contact with the housing gaskets left and right. Good luck! Larry shepard |
