turning rear brake drums Any one in central NJ know of any one who can cut rear drums, need to get a pair done.
Re: turning rear brake drums Reid's auto parts (NAPA) in Scotch Plains. Just did a set for me a month or so ago
Re: turning rear brake drums Any good brake shop should be able to do it.
Re: turning rear brake drums Quote:
MOST shops any more don't have the 11/16" arbor (similar to BELOW) required to do the job. Coop https://www.fordbarn.com/forum/attac...2&d=1555861438 |
Re: turning rear brake drums The older drum turning machines had the arbor to fit early Fords but not so many have them in the modern era. Call your local shops that do brake drum service and see if any have or know of someone that has an older machine that has the small shaft arbor in it's tool set.
