33 Tudor eliminate spare on the back What do I need to modify to be able to use a donut spare for my 33 Tudor sedan?
Re: 33 Tudor eliminate spare on the back If your spreader bar under the tank cover has not been modified all you need it the cast bracket that mounts on top the tank cover.The original spreader bar has the support for the bracket.Those brackets appear quite often in the classifieds or that auction site.
Here is one.They are 3 listed https://www.ebay.com/itm/16626024482...Bk9SR8rWjM7IYg |
Re: 33 Tudor eliminate spare on the back Deuce, I want to REMOVE the spare on the back for a smoother look.
Re: 33 Tudor eliminate spare on the back Sorry I misunderstood. Where do you want to put that donut spare?
Re: 33 Tudor eliminate spare on the back Probably just set it in the back seat.
Re: 33 Tudor eliminate spare on the back Remove the bracket and leave the spare tire in the garage and carry your cell phone.
Re: 33 Tudor eliminate spare on the back Will the donut fit behind the rear cushion? My tudor had a hinged back cushion. Newc
Re: 33 Tudor eliminate spare on the back From what car could I get a donut that fits or will I need some kind of adapter? Has anyone done this?
