Holley 4000 - Advice Needed I'm trying to sort through my Holley 4000/Loadomatic distributor issues. I had to replace the double diaphragm advance mechanism on the distributor and I had a couple issues with the Holley 4000 that Pony rebuilt for me. The choke was assembled wrong and was bound up. Sorted that out and got the choke working the way it should and it starts very easily now.
Here's my question... The carb has a bit of a stumble to it. Get on the accelerator and there's a definite hesitation. For warm weather, Ford recommends the shorter stroke on the accelerator pump. Pony assembled it with the pump linkage set up in the winter position. In the summer position, the rod would easily pop out the back. But in the winter position, another piece of linkage is in the way and has to be removed. So before I take all of the linkage apart, I figured I would ask if more of a gasoline squirt could cause the stumble? In theory, will changing it make it better or worse? |
Re: Holley 4000 - Advice Needed From what I've heard, Pony does a lousy job on teapots. I can't help you on your problem but there is a guy in PA that does great job on teapots. Mike Suter, 215-757-3678. He actually runs them in on an engine.
Something else you might want to try. Advance the initial timing to about 10 degrees. Sometimes this will fix a hesitation. |
Re: Holley 4000 - Advice Needed Quote:
I have spent a lot of time and effort trying to make this system work properly. I actually have improved it very dramatically. I still work and don't have the time to spend with this. With very few people still around who know how to fix them, sorting these things out is difficult. That's why I've decided to slowly gather up everything I need and convert it to a 57 setup. I predicted that the purists would jump all over me - and they have. But it shouldn't have to be this hard. While I like working on cars. I have five of them. This one costs me 80 percent of my time and is driven the least. |
Re: Holley 4000 - Advice Needed A stumble on hard acceleration usually is a lean spot in the RPM band. The winter squirt position is richer, so that should solve your problem. Often, when people degrade your restored car, they secretly wish it were theirs.
Re: Holley 4000 - Advice Needed I can't imagine how Pony Carb made such a mess of your complete rebuild and are not willing to remedy the problem. Why don't you return the carb to them?
Re: Holley 4000 - Advice Needed i changed mine with a 62 ford p/u 292 dizzy from autozone came loaded cap/points for $50-60 .and went with an edelbrock 1406 4 bbl runs great still have the old manifold and carb if anyone needs it.
Re: Holley 4000 - Advice Needed There is a guy out west that has built carbs for 35 years. His name is Mike Mitchell. He has a great site with a lot of instruction, carb kits, etc. His kits include parts that are obsolete in other kits. If you want to know about rebuilding a teapot search Youtube...Holley 4000 teapot rebuild. Look for the author to be Mike's Carbs. There are 6 or 7 parts showing step by step to completion. There is over an hour of free instruction. Mike's carbs is Mike Mitchell. I bet if you mailed him he would help.
http://www.carburetor-parts.com/ |
Re: Holley 4000 - Advice Needed If you hold the primary throttle in the wide open position, the accelerator pump link will easily slip out of the hole. John
Re: Holley 4000 - Advice Needed It sounds like your pretty sure there are no issues with the Load-O-Matic ignition and you are getting correct spark advance.
I have been doing these Holley 4000's (and 2140's) since around 1968 and have learned quite a bit about them. If you are getting a stumble from too much accelerator pump shot, them a breif shot of black smoke out of the tailpipe should be visible when this happens. It's more than likely not enough pump shot causing the hesitation/stumble. With the engine off, and holding the two choke plates wide open, try to look inside and locate the two little brass nozzles where the accel pump shot comes out of. You may even need a mirror. Kind of hard to see with the carb installed. They are short tubes on an angle. You should be able to see a shot of fuel come out of each with the slightest movement of the primary throttle lever. It's possible Pony Carbs installed the pump piston too high (parts from other carbs can do this), and the piston is above the point of sealing the pump bore. This will at least give you a starting point to know what you have now. Wish I was closer to help you out. I've sold these on EBAY and take the time to do them correctly. Never had any complaints. It is arguably the most difficult carb to assemble and assemble correctly. There is a difference between just cleaning and re-assembling with new parts and doing it correctly. Sal Cicala (313) 805-0159. |
Today I drove the car back and forth to work and again it seemed to get a bit worse. I started to experience heavier pinging. Decided to put the light on it again and take out a little more timing. The light showed it to be about 20 degrees advanced. Talked to my buddy and he told me that the same thing happened to him. He set it once and then checked it again later on and the timing had shifted about 20 degrees. Two questions... What the heck would do this? And the vacuum lines... Normally you disconnect and block when setting the timing... What do you do with the Load O Matic? Do you disconnect both? |
Re: Holley 4000 - Advice Needed Bad Pertronix? I'm now wondering whether my timing issue may be my Pertronix.
Re: Holley 4000 - Advice Needed Not trying to steer you to an other website, BUT, go to the YBlocks forever site. A lot of knowledge about everything Y block. Hoosier Huricane that left a comment here knows everything there is to know about this engine.
