Another gas gauge install question. Spinning as I tighten it Hi All:
I went to snug up the gas gauge and the gauge itself is spinning as I try to snug up in the inner nut. I fooled with for about an hour and couldn't get it not to do that. Any thoughts as to what I'm doing wrong or how to stop it from spinning? Thanks, Tim |
Re: Another gas gauge install question. Spinning as I tighten it Tim,
Are you using the proper tools to tighten it up? https://www.snydersantiqueauto.com/p...9367&cat=41753 |
Re: Another gas gauge install question. Spinning as I tighten it |
Re: Another gas gauge install question. Spinning as I tighten it 1 Attachment(s)
You need two metal slip ring gaskets with a drop of oil between them. that will do the trick.
Re: Another gas gauge install question. Spinning as I tighten it Quote:
Re: Another gas gauge install question. Spinning as I tighten it I had the same problem, I kept adding the brass washers ( was up to 6-8 ) finely I added 2 extra washers in the housing before the assembly with the 2 normal washers. I feel the cork gaskets are thinner than original’s .
