Re: Gas rust Quote:
Re: Gas rust Quote:
Re: Gas rust Quote:
Re: Gas rust Has anybody tried the 6% vinegar for 2-3 days? The motorcycle world uses this quite frequently. 2-3 days industrial vinegar, flush with water, spray and pour lots of WD40 at it repeatedly to suck up the water, use air to dry, more WD40 to stop flash rust etc. You can't roll the tank around if it's in the car, but if its right full it is covered. Petcocks have to be removed and they use really good duct tape -Gorilla brand. Just wondering if it would knock down a high percentage of the problem.
Re: Gas rust nobody even mentioned henry fords idea of a filtered stand pipe in the tank....attatched to the fuel valve....put on valve before installing the assembly... keeps from picking up trash from bottom of tank...most suply outfits sell them....couple bucks ...fixed mine.....kev:)
Re: Gas rust Had the same problem on a roadster. Looked like the old powdered snuff I used to see old timers dipping. Ended up taking the tank off and had a radiator shop boil it out and seal it with a red stuff. Not sure what it was called but they said it would hold up. We don't run ethanol in anything we own so maybe it will be alright.
The tank had to be painted after it was sealed. It was a job getting the tank out and back in but I wanted to eliminate the problem. The way I see it the rust is metal out of your tank. The tank is eroding away and magnets are a bandaid not a cure. jmho of course. I may have done wrong with the sealer but so far no more snuff in the bowl |
Re: Gas rust Quote:
Re: Gas rust FWIW: One experience:
Any gun owners? Try going duck hunting on a body of water on a foggy cold morning in a humid area where gun metal gets cold followed by later warmer moist breezes when the sun come up which causes warmer moist air to contact colder metal & cause condensation. Hunter A oiled his gun before leaving home, Hunter B did not -- whose gun has rust? Gas tank metal, like all metal, is porous & sloshing gas alone can remove oil from metal; however, if one adds oil like Marvel Mystery oil, (4 ounces per 10 gallons of gas), small amounts of oil can soak & get down in the gas tank metal pores & help to prevent further rust. Experiment: Soak (2) clean pieces of rusty steel in liquid solutions for (3) weeks: Piece G in gas alone; Piece O in gas mixed with oil -- remove & allow both to dry -- immediately paint both with paint -- allow to dry & let sit in sun -- did the oil affect the paint's adherence to the metal on Piece O, or is it your imagination? Dry arid regions as opposed to humid regions make a substantial difference in gas tank rust deposits, especially in high humidity Coastal States -- ever guess why modern inboard boats left in the water have fiberglass fuel tanks. Works for me! |
Re: Gas rust Dog:cool: here, Duz sumbody have the TEKNOLOGY to make us sum fiberglass RE-PRO ges tanks fer ur Model A's?:confused:?? Buster T.:cool:
Re: Gas rust Well with further inspection of my fuel tank today, More bad news. First of all, I drained what gas I had left in her. I pulled apart the Glass fuel filter I installed under the dash. All that brown powder looked like rust, yet not magnetic, So I would guess oxide is not magnetic because it would not stick to a magnet at all. Then I pulled the valve an all out of the bottom. There was a stand pipe already installed. I used a blower to blow out tank fumes for a few minutes, then shop vac'ed out the best I could inside. While looking under the tank, I noticed paint bubbles and damp around the steering column mount, an other spots. Now I am thinking that I may have to pull my tank out for repair or replacement. :eek: This now has me scared because it looks to be a big job, an don't want to ruin a good car. My next steps now is a lot of research. repair or replace ??? And, How the hell does that come out ???
Re: Gas rust Well, Wild Willy, Dog:cool: here,
Chief tole Ol' Bill & he tole me, IT'S JIST BOLTS, NUTS, & SCREWS, to gitter' out! NO TORCH required! LOL:D Buster T.:cool: |
Re: Gas rust Quote:
The only way to save the Car and Yourself, is to remove the Tank and Have it Fixed or Replace it with a Good Known Tank. Its not a big job, You just have to be careful removing and Installing it. Stop and think about it, If You Value Your Life and your Model A, Fix it the right way. |
Re: Gas rust Thanks Bill. Looking at all the cowls in the swap meet area, I am thinking of just repairing mine. All the ones I looked at are in ruff shape and rusted to high heaven. Have done some research on tank sealants, they make some high tech stuff now to handle the new fuels out there. Im going to take my time, an try my best to do this right the first time.
Re: Gas rust LOL, Thanks for your concern on my safety Jazzjr, I used my air blower off an air tank that was 50 foot away for a while. Had gas gauge out too for added air. did not vac til the smell was real week an felt safe enough to go for it, was a nice clear day with a slight breeze, an done this in the great out doors for best venation. Was in no mood to go Boom today. LOL
