air cleaner Would any know of an after market air clean to fit the 97 carb that will not restrict the air flow, or,
I would like on like an original 33 that I could pit a modern paper element inside. Thanks Lawrie |
Re: air cleaner Here's the K & N Air Filter web site page for searching filter shapes and sizes .... http://www.knfilters.com/search/universal.aspx ....
Use this and other forums "search" feature to find threads discussing and detailing the conversion of stock oil air cleaners to concealed paper filters, and the pro/con debate re same. Obviously there are retro units on auto/hot rod retail shelves if you're so inclined. |
Re: air cleaner Thanks ,I should be able to find something there.
Its for my 28 ccpu with a 97 carb . Lawrie |
Re: air cleaner This one is talked about a lot.
http://www.knfilters.com/search/prod...id=526551&rw=1 Another choice is the high profile one here. http://www.otbgear.com/Dome-Top-2-Ba...-Tall-P12.aspx |
Re: air cleaner 1 Attachment(s)
This is what I use on my model A 97. The base is a speedway Louvered air cleaner base with a hose clamp to hold it on. I do not like using a set screw into the carb. The top is from another Speedway air cleaner. K&N from chart,don't remember number. So I used 2 cheap air cleaners to make one.
John |
Re: air cleaner K&n e-3130
Re: air cleaner i bought mine at macs.i think its 7 inch dia.chrome is made of heavy sheet metal it was about 80 bucks but doesnt restrict and looks great.
you can get creative and make something unique! Here is by twin version with a K&N inside:rolleyes: (Click to enlarge)
Re: air cleaner My P.S. for you ..... check this .....
http://www.jalopyjournal.com/forum/s...air+conversion Its an 8Ba Oil Bath conversion to paper but a good write-up that might help you. |
Re: air cleaner Lawrie, PeterC's air cleaner is very well done, and keeps the theme of the original '35 (actually the same for '34-'36) air cleaner to a "T"... IMO.
I also know of two other FB members who have come up with some very unique and creative modifications, for this same year stock air cleaner, allowing it to accept a modern replaceable air filter, and if someone didn't know otherwise, would think they look, and are, 100% original. |
Re: air cleaner I have installed a K&N filter in my original 1933 breather. Works great and keeps it looking original. Sorry I forgot the Part# of the filter
Re: air cleaner 6 Attachment(s)
For my right hand drive (UK) 1932 Model B I fabricated an air filter to replicate the original aftermarket version that was available for left hand drive cars. I added the drip tray which is useful for catching any petrol which drips from the carburettor. The filter housing contains wire mesh. It's more ornament than function !
