30-31 AA frame City:
Wilmington
State:
DE
Price:
see add
I have frame for a 30-31 AA, that I need to let go of. I am moving, and can't take it with me. The frame is rusty, and pitted, but solid enough for a second life (in my opinion). All of the crossmembers are there. The front crossmember is fairly pitted, however, and would benefit from someone welding up the pits a bit.
The frame shows various alterations: The rear of the side rails were removed at one point. I am assuming this indicates, that the frame was used for some sort of dump truck. A modern, "c" channel, box frame was later added on to the end, where the original frame ends once were. This modern alteration could be cut off without difficulty. The rear spring mounts were removed, and two pairs of front spring mounts were welded to the frame. This was probably done to mount the rear springs upside down. These, two, could be cut off. I believe that all of the brackets (running board, etc) were removed. I may have them somewhere, and will probably come across them as I clear everything out during my move. They would be sold separately, however. I'd like to get $100 for this. A buyer would need to pick it up in person. A potential buyer really should inspect it first. I would be able to help load, and probably have equipment sufficient for the job. If I don't get any interest on this, I will cut it up for scrap, saving the engine end for use as an engine test stand. I can be contacted at: [email protected] Thank-you for your attention |
Re: 30-31 AA frame If I get no interest on this in the next month, I'll have to cut it up for scrap.
