30`s v8 wire wheels Will the later 30`s v8 wire spoke wheels fit the 1930 A drums?
Thank you. farmerdick |
Re: 30`s v8 wire wheels Yes
Re: 30`s v8 wire wheels The 1930 pickup I bought had the later wheels on it. Don't think any adapters were used.
Re: 30`s v8 wire wheels I met an early V-8 guy at a swap meet recently who complained that so many of the Model-A guys were installing the V-8 wires that he was having trouble finding any for his restoration. If so, I haven't seen any corresponding increase in the availability of good Model-A wheels.
Re: 30`s v8 wire wheels Any wire wheel through 1935 will fit the Model A drums (excepting AR, and there I am not sure). Where you get in trouble and need adapters is trying to run wire wheels ('28-'35) on the later hydraulic drums. Another time you need adapters is running '40-'48 (and probably later) solid rims on stock Model A drums.
Charlie Stephens |
Re: 30`s v8 wire wheels Thank you guys for the info. Do you think there would be any alignment issues if I used a smaller and wider tire?
Re: 30`s v8 wire wheels Quote:
Re: 30`s v8 wire wheels If I go to a 16" rim and put on a wider radial tire, would there be alignment problems.
Re: 30`s v8 wire wheels NO Why would there be if it was right before the wheel change??
Paul in CT |
Re: 30`s v8 wire wheels Great. Just wasn`t sure if there would be with the radical change in geometry. Thanks much.
Re: 30`s v8 wire wheels When going from 19" to 16", it will throw the speedometer off by ???mph - probably the odometer too.
Re: 30`s v8 wire wheels The radial tires will require a different camber than the bias ply tire.
Re: 30`s v8 wire wheels 4 Attachment(s)
Since questions about wheels and adapters come up frequently I thought I would post a couple of pictures on the subject. The wire wheels from ‘28 (I am not sure about the AR wheels) through ‘35 are designed to mount on a surface that has 2 levels. The first photo shows the ring on the rear wheel of a Model A that provides this second level. Beginning in late ’31 with the cast drums and continuing through ‘35 this second level was provided by raised nubs as shown in the second picture. All wire wheels (including aftermarket Kelsey wheels) can be run without adapters on the brake drums intended for mechanical brakes. The wheels for ’40 through ’48 were designed to run on flat drums as shown in the third picture. There is an adapter shown in the fourth photo that provides this second level when running wire wheels on hydraulic brake drums. There is a spacer available to run the later disc wheels on the mechanical brake drums. In both cases it is necessary to check that the studs are long enough. The spacers to run wire wheels on the later hydraulic brake drums are available from MT Car Products as part # 5000, Speedway as part # 91065470, and Sacramento Vintage Ford Parts as part # 05199-8 as well as many other sources. Since all wheels had the same 5 on 5 ½ bolt pattern the wheels can be bolted on and appear at first glance to fit. Unfortunately, not running adapters/spacers when they are required may result in cracked rims.
Re: 30`s v8 wire wheels A few thread ago, I spoke about having my front end aligned on a machine that could correct the camber by bending the axle. I have 16 inch wheels and the new Coker 16 inch radials. When I got to the shop, the tech checked the camber and it was 1* positive. His opinion was that we should not change it and that the tire would run fine with 1*. Mind you, his shop has been doing front end alignments for over 40 years. The toe-in was adjusted and off we went. The bigger problem was wheel balance. A couple of the wheels had some wobble that presented problems, but there were work arounds. All in all, very satisfied with raidals...
Frank |
Re: 30`s v8 wire wheels This is for future changes I want to make to the car and appreciate the information. Thank you.
farmerdick |
Re: 30`s v8 wire wheels 1 Attachment(s)
https://itunes.apple.com/us/app/spee...307529605?mt=8 |
