Fuel pump kits Does anyone handle fuel pump repair kits? Thanks Jim
Re: Fuel pump kits VanPelt Sales, then get pump diaphragm from Charlie NY.
Re: Fuel pump kits I have Fuel Pumps -- New & N.O.S. --
And fuel pump kits in NEW ethanol gas compatible material.... Always best to simply call me -- Craig -- 516 - 485 - 1935..... |
Re: Fuel pump kits When installing any pump streatch the spring to get slighty more than
4lbs pressure when the pump is cold. As the temp raises the pressure drops. At 3lbs it will start to vapor lock when it's hot. A small return line allows the fuel to keep flowing, cooling the pump with very little chances of Vapor lock. Need about a 1/16 orfice so to much fuel don't return. To much return will act like a governer at high speed. G.M. |
