Correct spindle ??? 2 Attachment(s)
A year ago I was trying to find the correct spindles for my 35'.
I let be known to a few people what I needed and the other day when I arrived at my shop I found an anonymous box with 2 pair of spindles inside. The photos shows 3 pair: 1st photo,left to right; A B C, The hub shaft lengths are l-r 5.5", 5.75", 5.5". The hub shaft diameters are all the same. The kingpin diameters l-r are .815 , .815, .941. (all inside bushings) The axle openings are l-r 2 15/16, 2 1/2, 3" . The drag link to tie rod hole center to center are l-r, 1 1/2, 1 1/4, 2 1/8. A or B must be the 35' , 2nd photo ,the rears in reverse order. ID help pleeeze. |
Re: Correct spindle ??? (A) is a a 37 to 41
Re: Correct spindle ??? C is not 35 Ford (Is it Lincoln?) 35 Ford has .8125 king pin diameter.
Re: Correct spindle ??? '35 hub shaft length is 5 11/16"; '36 hub shaft length is 5 7/16".
'35 right arm is 1 1/2" between holes; '36 right arm is 2 3/16" between holes. |
