The Ford Barn
-   -   thread renovation ? (https://www.fordbarn.com/forum/showthread.php?t=236331)
hardtimes 12-31-2017 01:42 PM
thread renovation ?
I'm working with antique aluminum parts, removing brass plugs frozen with time 80+ yrs time. Feeling lucky to have removed some parts, so far, without breaking any casting. Aluminum oxide has made the bond and has indicated that the aluminum threads should be cleaned.
If I do not have right sized taps for the, too large hole, do you know of any way to clean these alum threads without damage ? I will put some lube on reassembly to help prevent recurring problem.
cas3 12-31-2017 01:46 PM
Re: thread renovation ?
you get a bolt that same size and cut some slices in it with the whizz wheel. you have now made a thread chaser!
hardtimes 12-31-2017 01:57 PM
Great idea, I'll think on that one and look for bolt :) !
Also, wondering will any 'chemical' dissolve the oxide and not harm thread ?
glennpm 12-31-2017 05:57 PM
Good idea that cas3 has. I have one of these kits which is hardened steel that is configured the same as he mentioned. This kit works very well!
http://www.sears.com/craftsman-48-pc...p-00942275000P
19Fordy 12-31-2017 06:35 PM
Here's a whole bunch of ideas on how to remove aluminum oxide without
damaging the aluminum.
https://www.google.com/search?ei=OXN....0.aRtxl_zyFL0
rotorwrench 12-31-2017 06:57 PM
If they are US nation pipe thread, you could get NPT taps for most sizes. If they are bolt thread national fine or course, the thread chasers will work or an old bolt with some flutes cut into it. Steel wire brushes like the ones used to clean battery terminals may also work. It just depends on what size they are.
grumppyoldman 01-01-2018 02:17 PM
If the hole's are already too large, you can repair them with a Helicoil kit. They are sold at most auto part's stores. you tap the hole with a special tap and install the helicoil for the proper size bolt. Al
hardtimes 01-01-2018 05:29 PM
Oooh, that will work, thanks for that:) !
Copyright ©2000 - 2019, vBulletin Solutions Inc.
