The Ford Barn
-   -   1936 Ford Pickup battery placement? (https://www.fordbarn.com/forum/showthread.php?t=272888)
Ngnear 11-19-2019 05:27 PM
Where did Ford locate the battery in 1936 1/2 ton pickups?
Kerk 11-19-2019 06:16 PM
Re: 1936 Ford Pickup battery placement?
It was originally under the floor on the drivers side On 2 brackets on the frame. It was accessed under the floor bboard which also had A metal plate
to check it or add water or acid. Hope this helps, It is the same for the cars also . kerk
Copyright ©2000 - 2020, vBulletin Solutions Inc.
