The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   bolt torque difference iron block & Aluminum Head (https://www.fordbarn.com/forum/showthread.php?t=278573)
callbald 03-27-2020 09:01 AM
Ok, up popped a rattle in my Galaxie 289 water pump that has to be replaced. The engine had been converted to aluminum heads. The shop manual calls out 12-15 ft lbs, but that's for cast iron block and heads. Any idea what torque to use on the aluminum heads? Thanks Rob
40 Deluxe 03-27-2020 09:51 AM
Re: bolt torque difference iron block & Aluminum Head
As I remember, those are 5/16" bolts so the bolt itself is the limiting factor. 12-15 ft. lbs. should be OK in aluminum as spark plugs in aluminum heads are torqued to around 20 ft. lbs.
darrell 03-27-2020 02:37 PM
the water pump doesnt bolt to any head.nothing would change.
callbald 03-27-2020 03:42 PM
Your are correct, it does not bolt to a head. I was looking at the head bolt holes for the P/S bracket. This rebuild is getting the better of me.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
