Gasification |
Re: Gasification The engines for these were fitted with a special heads. These ones burn wood but there were also coal burners.
Re: Gasification Has anyone see a "LOWER" compression head for the Model A Ford stateside?
And when he says "low" he may be meaning a "standard" head rather than the Model B head which others have said were fitted to most GAZ trucks? Joe K |
Re: Gasification |
Re: Gasification Quote:
There are different numbers out there but the wood burner GAZ-42 was rated around 34hp/2400rpm. And it received lower gearing of 7.5 The GAZ-AA story is complex. When B engines (called "M" engines in Russian) were introduced A engines continued to being made and fitted to trucks. WW2 era A engines exist. The GAZ-AAA and armored cars were 1st in line for B engines. There were also "AAZ" engines that were A blocks fitted with hi-comp heads. There were also been hi-comp heads for B engines. My guess is these wood burners would have received B engines with the hi-comp heads mentioned above; but anything is possible especially during WW2. |
Re: Gasification |
Re: Gasification |
Re: Gasification |
Re: Gasification |
