Any clues on light switch stiffness? I am rewiring one of my A's. The switch would seldom turn (in the center of the steering wheel) and the few times I got it to move it blew a fuse or tripped my breaker. Before installing the new wiring harness I tried the new harness with the old switch and though it moves better it isn't a whole lot better than the old one. The new wires look more intact and I turned the lower bushing on the steering gear so that now the bail locks the switch from the bottom instead of the top. (Turned the bushing so the slot for the switch is on the bottom, it had been on top.) Just wondering if anyone else has suffered with a stiff switch and how they got it to loosen up? Lube, what kind and where did you put it, it you did? With the switch removed the light and horn rod spin freely and don't appear to be the wrong length or bent in any way.
Re: Any clues on light switch stiffness? Are you sure your switch is an origonal? some of the repops have too pointy and too small of contacts so they seem to lock in tighter to the concave contacts on the harness.
If it is original and your sure your horn rod is the right length then some use dielectric grease on the contacts. |
Re: Any clues on light switch stiffness? I wondered about dielectric grease. The tube says it has an insulating quality. Seems to me that isn't what I want there. I'm fairly sure the switch is original though the wiring is not. I got that from Sacto Vintage where I understand make there own harnesses in house. I used some paraffin and that seems to have helped out. I found the headlight socket piece to have such large ends on the wires that the two wires when pushed back by the bulb, contact each other. The wiring in the right hand bucket was incorrect, high beam where the running lights should be and running light and low beam wired into the headlight bulb holder. I'll fix that tomorrow with a bit of heat shrink and filing the contacts. Probably have to use a stone as they appear to be stainless. Should buy new bulb holders but I read the are also foreign made and "fair" quality. My fix will probably be a step above fair quality. I like the vendors that are honest enough to warn you before hand, but wonder why they don't insist on a better product. I guess we are just too cheap to make that good business sense?
Re: Any clues on light switch stiffness? I just installed a new harness on my A yesterday, the new switch block was thicker then the old one and when installed prevented the switch from turning, I removed 1/32" from the back side (where wires attach) and all worked well when installed.
Re: Any clues on light switch stiffness? Quote:
Hmm SVF I've heard does make the best wiring harness. In the small flat of the main switch on the outside there should be a B&S stamped in it. |
Re: Any clues on light switch stiffness? Side note: Some think steering box oil leaks into light switch screws it up. Others say it makes it work smoother. WHO in the HELL do you believe???---LOL or NLOL???
Bill Confusedstill?? |
Bill Brave |
