The Ford Barn
-   -   35 V-8 stud instlation (https://www.fordbarn.com/forum/showthread.php?t=243687)
whizzernick 05-03-2018 09:54 AM
any special sealant to put on studs in my 35 V-8 ?
Their several thread inserts .
Bored&Stroked 05-03-2018 11:17 AM
Re: 35 V-8 stud instlation
Yes - I always use a good coating of PTF based stud sealer . . . ARP makes some and it is good stuff. Also, coat the sides of the studs with anti-seize before you put the heads on.
https://www.jegs.com/i/ARP/070/100-9904/10002/-1
Good luck
Marvin/TN 05-06-2018 02:08 PM
GM has a Teflon based sealant to use of Studs that go into the water jacket. Not a tape but but kinda of a paste, comes in a tooth paste type tube. Can't remember the P/N number for it at the moment.Should be able to get it at any GM dealer.
B-O-B 05-06-2018 03:37 PM
permatex thread sealant with ptfe
