Help identifying part Need help with a fitting, Not sure what its called. So the copper tube that connects to the top of the timing cover and then leads to a fitting at the base of the carb (may be in the intake). The fitting goes thru the copper tube end like a brake line. Then has a hose barb on the end of it. I hope I'm explaining this well enough. On a side note, whats the tube for?
this is the best picture I could find online of it. Currently at work so i cant take one of my broken one. Thanks in advance !!! And if anyone knows where i can buy one ?? https://encrypted-tbn0.gstatic.com/i...eFzZSyT_5fHdBA |
Re: Help identifying part That's a useful fitting. It screws into the manifold and takes a banjo fitting for the ignition advance and retard vacuum pipe and also provides a connection for the vacuum wipers.
Re: Help identifying part I THINK that gizmo is called a muffler or silencer. Anyway, I would send a PM to barnfind08, another member here on the forum. I'd bet he has them NOS. That tube supplies vacuum to the vacuum brake on the distributor. DD
Re: Help identifying part Thanks for the info, no I need to find one :)
Re: Help identifying part The P/N 11A 17595 and is called a silencer.
Re: Help identifying part Thanks for the part number gary
Re: Help identifying part Quote:
Sceptre...In my previous post, I suggested sending a PM (PRIVATE MESSAGE) to barnfind08. Barnfind08 is a member here on the FordBarn that does a great old Ford original parts business. More likely than not, he will have that 'silencer' among his many barns-full of NOS (New Old Stock), real Ford parts. His name is Fred Wilner. Contact him by PM and ask if he has that silencer? I've set you a link below to contact him. Just click the link and fill in the subject, and a message asking about the part. Good luck! DD https://www.fordbarn.com/forum/priva...do=newpm&u=104 |
Re: Help identifying part I’ve sent him a pm, thanks !
