thermostat I'm in the process of replacing the radiator in my 30 coupe, do most cars use a thermostat? Thanks, Keith
Re: thermostat i use a stat and hold it in place by cutting an old lower hose which fits inside the upper hose... no external visible clamps needed...
Re: thermostat It helped my car a lot. I just slipped it in the upper hose. pressure pushes it to the top and it just stays there.
Re: thermostat its best to have it closer to the water outlet.....
forgot to add that i usually drill a couple more bleed holes into the thermostat frame |
Re: thermostat I use one. It's especially good on a cold morning. Warms up in a mile or two.
Re: thermostat I installed mine years ago and did it the same way Mitch does. I also drilled two 1/8" bypass holes.
Re: thermostat 1 Attachment(s)
I use this nifty little device that I got from Vintage Precision Products. It uses an "off the shelf" thermostat and has the two 1/8" bypass holes built in. Also has ports for a temperature gauge, and a hot water heater if so desired.
Re: thermostat Never use one, and never had an A that had one.
Re: thermostat Keith
It's a good thing to run. I've run one for over thirty years. If you have a good radiator, the engine never gets to the optimum temperature and runs cool. The thermostat makes sure your engine runs at 160 or 180 depending on which one you run. |
Re: thermostat Quote:
You "messing" with good engineering!! On Minerva, the 160 stat would flow more water on a cold start, than you could imagine ! From the provided vent hole & "maybe " some from the pressure pushing the valve open slightly" Yo' Dad |
http://www.vintageprecision.com/prod...ing/index.html |
both Tom W and i do the same thing with the extra holes.... you cant argue with that:) |
Re: thermostat [QUOTE=Mitch//pa;1055696]Yooo Poparooooni,,
both Tom W and i do the same thing with the extra holes.... you cant argue with that:)[/ I agree with anything you or Tom W say because I know you guys know what you are talking about. Mitch or Tom do you have a picture of a stat that you drilled out for someone like me to see so I do it right. Thanks Tom F.... |
[QUOTE=Tom F OHIO;1055884]
just do the same thing 2 more times equal distances apart... |
Re: thermostat [QUOTE=Mitch//pa;1055885]
Re: thermostat With thet many holes, it's an UN-THERMOSTAT!! May as well put a CROOKEDY stick in the hose. When we were WAY poor, Chief used a LARGE flat washer, to keep the engine & our BUNS WARM!!
Poor Bill W. |
Re: thermostat [QUOTE=Tom F OHIO;1055886]
Re: thermostat [QUOTE=Mitch//pa;1055964]
