'39-'40 trunk mat in a '37 ? Hey Guys ! Does anyone offer a trunk mat for a '37 coupe ? I have not seen any available for '37 . So, has anyone used a '39-'40 coupe mat in a '37 coupe ? If so, is it close ? Did it need to be cut back on the sides ?
Is it too short ? Long ? Thanks in advance ! - FF |
Re: '39-'40 trunk mat in a '37 ? According to the EFV8 '37 Restoration Book > "The floor of the luggage compartment was covered with embossed Morrocco grain black paper"
This stuff was similar to thin tar/roofing paper. I don't know where you can purchase this stuff but if you find it you'll have to cut it to fit.... |
Re: '39-'40 trunk mat in a '37 ? Quote:
Re: '39-'40 trunk mat in a '37 ? Thanks guys , but I want to go w/a rubber mat , as my car is not stock or original anyways .
Re: '39-'40 trunk mat in a '37 ? You could consider something like this > http://www.dhgate.com/product/rubber...srp|1561256944
Re: '39-'40 trunk mat in a '37 ? Somebody must make the mat, my '38 club coupe has one it it. It was in the car when I bought it.
Re: '39-'40 trunk mat in a '37 ? Not to hack in but my 40 trunk had the tar paper in the trunk but also has the fine stones on one side just like rolled roofing? Ford never used it with the stones on it did they? Thanks
These guys are right , the '37 book says they never had a rubber mat , just the black paper material . Kinda explains now why nobody makes one ! I was just hoping somebody on here had used a '39-'40 , and could tell me if/how it fit in a '37 . - FF |
Re: '39-'40 trunk mat in a '37 ? I went to look at mine. It has embossed in the rubber at the rear of the mat:
V8 Shop Quality Reproductions 1938-1940 Ford Coupe Trunk Made in USA |
However , it looks as though the '40 mat fits back through '38 , and if it fits a '38 ok , then (I believe ) it will fit a '37 ok . I will take a chance w/a'39-'40 mat from one of the current suppliers . 40cpe , I think you may have solved it . ;) Thanks to all who chimed in on this one . Love the Barn ! - FF |
Re: '39-'40 trunk mat in a '37 ? If you still have the brackets for the spare tire shelf you will have to cut those openings. My '40 is gone, so I can't measure to compare sizes.
Re: '39-'40 trunk mat in a '37 ? that building paper had to smell bad.
Re: '39-'40 trunk mat in a '37 ? Thanks Kube!
