Holley teapot I am trying to find a parts explosion drawing of the Holley EAC-9510 "teapot" carb for my 52 Merc engine. I know nothing about it. Thanks
John |
Re: Holley teapot Mac Vanpelt has some stuff on Holly carbs,not sure if it applies to yours.
http://www.vanpeltsales.com/FH_web/F...-51cutaway.jpg John |
Re: Holley teapot John,
That cutaway is for what I call "covered " carb. The 52 is "open throat". Thanks |
Re: Holley teapot The shrouded carb works the same in theory but it just had the shroud and a different style of air filter. As least with those open type you can usually see when there are leaks between the bowl housing and the throttle body. They didn't call them the towering inferno carb for nothing. A guy has to make sure the parts fit well together. If there is too much warpage then it's time to find a better core carb for parts. You can buy CDs now that have copies of the parts & maintenance instructions for these cars. It's usually less expensive that buying the hard copy manuals. I'd suggest Detroit Iron Information Systems CDs. They may be available from repro parts sources or flea-pay.
Re: Holley teapot I had one on my first car, a 55 mainliner, caught fire at least a couple times on me.
Till I had my dad's best friend rebuild it. |
Re: Holley teapot How about the Holley manual for your carburetor: http://www.oldcarmanualproject.com/m...952/index.html
Re: Holley teapot 9510 is the base Ford part number for carburetors. EAC-9510 is the Ford part number for the Holley 1901 carburetor.
Re: Holley teapot If you are going to buy an overhaul kit, there is one in there. If not, PM me with your mailing address and I'll send you an extra copy that I have out in my garage.
Re: Holley teapot 38 coupe. Thanks, That is exactly what I am looking for. Thanks to the others also. A very comprehensive manual on this carb.
Now, for all the folks that think that vapor lock was invented by Fordbarners, Here is a paragraph from the manual that proves that even the old gas boiled. John " "The main body is mounted above the center of the throttle body in a manner which allows cooling air to circulate completely around it. This free circulation of air helps to cool the fuel in the float chamber, preventing percolation and hard starting when the engine is hot. Truly concentric airflow through the carburetor results from this method of mounting the main body, as the air flows vertically downward on all sides of the main body into each venturi. As a result of this feature, the Carburetor Model 1901 has a concentric flow of air as well as a concentric flow of fuel" |
Re: Holley teapot The problems associated with vapor lock was the major reason this carburetor was designed. It kept the bowl well above the manifold. The design is not a bad one if properly maintained but it's problems arise with improper maintenance and fire hazzards that can come from that. The Holley manual, used in tandem with the appropriate FoMoCo manuals, will give a mechanic all the information he would ever need to maintain one for a speciafic model of car. The FoMoCo manuals are very comprehensive for the model affected and gives all design adjustments for each with additions of linkage adjustments for automatic transmissions and such. These are important to have if you have Merc-O-Matic or Ford-O-Matic transmissions.
Re: Holley teapot John, I'm using a 52 merc carb on my latest project. I found that an electric choke with a heater,(12v), bolts right on in place of the original. I bought it for an eldebrock carb, but fit the Holley just fine. I had a stock 53 monterey that got gas mileage in the mid twenty's Chuck S.
Re: Holley teapot Quote:
