Alternator vs. generator? I need to replace my generator. Not sure why it failed, but this is second replacement in 8 years. Most guys at the July 4 parade have replaced with alternators. I prefer to stay as original as possible, yet I drive my car regularly and need it to be dependable. What are the pros and cons of replacing generator with alternator? Am I the last generator standing?
Re: Alternator vs. generator? I have a generator as does a lot and love them? Do you have it set correct? What was you charging with it? I know guys that has ran same generetor for over 40 some years.
Re: Alternator vs. generator? I changed mine to a alternator and love it. Generators are just fine, but an alternator keeps your battery in better shape
Re: Alternator vs. generator? Mine is a Nu-Rex Alternator, so I don't have any Gen experience.
"Model A Times" did an article in the last 2 years about a Generator with a Voltage Regulator. There opinion was that it may be better than an Alternator. |
Re: Alternator vs. generator? You need a generator that needs to be reliable. I would say that for 35 years they were reliable before alternators became an option. What makes you think they weren't/aren't reliable? An EVT even makes them better. This has, however been debated over and over here as to why folks feel compelled to make the change to an alternator.
Re: Alternator vs. generator? Our club 60+ cars 3 alternators.
You can have the same bad luck with an alternator as a generator. You will find both camps with excellent results for either. Alternators charge the battery with 7.4 volts which is not ideal for the battery neither is a generator. Choose what you want either will work. A generator being original tilts the scales for me towards a generator, but that's me. |
Re: Alternator vs. generator? A generator with an electronic voltage regulator is the best of both worlds. I restored my powerhouse generator in 1995 and made an electronic voltage regulator to fit inside the rear cover to replace the adjustable third brush. I haven't had the cover off since, and don't expect to have to remove it again in my lifetime. My 6 volt battery came from a junk yard 10 years ago and is still going strong. I credit this to the generator with an EVR and a quality battery.
Re: Alternator vs. generator? I have owned an alternator shop fir 35 years. I can make a pos grd alt that cost me little in time or money. I run a generator.
Now as a side note if I ever get around to setting bearings in my powerhouse generator I'm gonna talk Tom into selling me a VR. I'm just to lazy that's all, (to work on the powerhouse.) When I got my car the generator was blown up....It was ran open circuit and an alternator doesn't like it either. I dug out an old core, all ball bearing, chucked a bearing in the front and re-packed the rear bearing. New brushes and the comm looked ok so I didn't touch it. It just keeps going...If it'll die I'll go play with the power house. It is just a personal opinion and nothing more but an alternator on a Model A just looks wrong to me. |
Re: Alternator vs. generator? I solved the Gen. vs. Alt. problem by having a Gen. on the '29 Coupe' and an Alt. on the '31 Sedan. Also did the same with white/blackwalls, and fat/skinny girlfriends. Oh, I use 20wt. in the '29, and 30wt. in the '31. Just trying to cover all my options.
Re: Alternator vs. generator? I have an EVR in my powerhouse that Tom prepared for me several years ago. Over 10,000 miles and not a problem. The battery has required a small top up once a year and all I can say is that the EVR modification is flawless!
Re: Alternator vs. generator? can camouflage an alternator, dynamo within the Original
https://fbcdn-sphotos-c-a.akamaihd.n...87727952_n.jpg https://fbcdn-sphotos-e-a.akamaihd.n...62025727_n.jpg |
Re: Alternator vs. generator? That's a pretty cool perception . . hiding the alt, but seems it will run hot.
Re: Alternator vs. generator? I love model As! I am not concerned if all my parts are ar correct to the month of production. However an alternator was not used by Ford for nearly 35 years after the last Model A rolled off the line. The are just"out of place" A generator is simple and they work well on Model As for over 80 years. You can solve the cut-out problems with a diode or EVR. And nothing looks out of place. Of our 4 model As the generators just have not been problematic. I love my cars because they look, feel and act like antique cars. If you want an old car with an alternator, easy steering, air conditioning, ect get you a late 60s ford and leave the old Model in tact or generations to come.
That is my opinion, I might be wrong. |
Re: Alternator vs. generator? in Argentina is impossible to get a generator so I had to modify
Re: Alternator vs. generator? Quote:
Re: Alternator vs. generator? Nlbloch,
I don't know why your generator failed either but I would suggest while running it did you have some slack 3/4"-1" in the belt. If you installed the fan belt too tight it sure will put a strain on the bearings. Cape Codder |
Re: Alternator vs. generator? Its sort of a personal choice. An alternator will do the job but will get insulting remarks from people with no manners. Alternators need the fan belt tighter that the generator for proper output. Running with the fan belt tighter will cause problems with the original type front water pump bearing. Worn front water pump bearings, caused by tighter than normal fan belt ,upsets the seal at the rear of the pump and causes leaks. The one wire alternators will require the engine to be reved up, so as to excite the alternator for the charging to begin. Alternators don't last nearly as long as a good or properly rebuilt generator. I rebuild my own generators and use the can style voltage regulator from Fun Projects (www.funprojects.com). Overcharging is usually the cause of early generator failure. The can style voltage regulator that takes the place of the cut out will allow the six volt generator to cycle from about 3 to 15 amps for power on demand, like a modern car. If six volts are not enough, Fun Projects has a can style regulator for six, eight, or twelve volt and no modifications to the original generator is required. Voltage regulation will extend the life of the model A generator and constant adjustment of the third brush for night driving will no longer be needed. The halogen bulbs that fit the original sockets will work with the model A generator. If you have lots of electrical accessories or the more powerful quartz halogen bulbs , an alternator will be a must.
Re: Alternator vs. generator? I generator or alternator will get you battery charged. I think many times a unfair comparison is made by comparing a new alternator to a generator that is about 80 years old and either old and tired or has had the brushes replaced and is expected to run like new.
