Spindle identification help please 4 Attachment(s)
Does anyone know what this spindle is? It’s drivers side and it’s a round spindle and the top is flat. Would this be a lincoln? Also the shaft is the same as 40 ford and accepts same bearings and hubs. Thanks
Re: Spindle identification help please See if it is marked 78-xxxx. Might be a modified 37-41 right hand steering ford spindle.
Re: Spindle identification help please Well, it's obviously for a right-hand drive car. It favors the round American '37-'41 spindles except for the flat portion at the top king pin hole. DD
Re: Spindle identification help please 1 Attachment(s)
Notice the step in the flange unlike a 40 ford however it was mated up to a 40 ford backing plate perfectly when I got it
Re: Spindle identification help please There are no visible numbers stamped on it
Re: Spindle identification help please I think it is a RH spindle for a LH drive car. Maybe Lincoln.
Re: Spindle identification help please But if it’s a RH side spindle the steering arm would go out the front?? It has to go on the LH side of car for the steering arm to face rearward
Re: Spindle identification help please Check the king pin inclination, IIRC Lincoln is 4* and Ford spindles are 8*. Could that flat have been put on it to clear the interference with a Lincoln backing plate?
Re: Spindle identification help please The top of the spindle looks like how we grind the 37-41 Ford round spindle for MT Lincoln brakes
Re: Spindle identification help please Quote:
Re: Spindle identification help please Lincoln spindles are more rectangular or squarish than round. Lincolns also have a king pin larger than .813". I don't believe they're Lincolns. DD
Re: Spindle identification help please Are you sure it's not aftermarket? Ford should have part number shouldn't it? Unless it was ground off.
Re: Spindle identification help please It sure appears to be original especially with that steering arm
Re: Spindle identification help please There are aftermaket spindles that match the originals.
Re: Spindle identification help please I’m thinking it’s a 40 ford (or aftermarket) right hand drive. That someone ground to fit lincoln brakes.
Re: Spindle identification help please Ok, after looking at the enlarged pictures, it is a LH spindle for a RH drive vehicle. My mistake. Do you have a pair of those or just that one? How did you end up with it?
Re: Spindle identification help please I agree on LH spindle for RHD vehicle, Probably 37 to 41 Ford with top area modified for Lincoln backing plate.
