What kind of jack do you carry Okay, trying to pull together a few items to keep in the trunk, right now its empty. First thing I was wondering is what kind of jack should I purchase in case of a flat. Looks like its going to need a pretty long throw.
Re: What kind of jack do you carry 1 Attachment(s)
jack daniels
Re: What kind of jack do you carry Quote:
Re: What kind of jack do you carry Since you didn't say what year -- the best jack for most early Fords is a scissors jack. I have found that one from a Ford Airostar van works best. It is completely self contained and with a piece of 2by8 as a base, you can get the frame up high enough to change a tire.
Re: What kind of jack do you carry Sorry, I have a 36 fordor. Since I have not taken the wheels of this vehicle yet, will I have trouble getting the tires out from the fender wells if I jack up the car on the axles? The frame distance from the ground is a long way up there.
Re: What kind of jack do you carry I have the original bottle jack for my 1936 Ford. In my 1941 Ford I have the original bumper jack but do not trust it, so I also carry an army surplus scissors jack from a Jeep that I use.
Sent from my iPad using Tapatalk |
Re: What kind of jack do you carry My 40 coupe is pretty low so I use a low profile US Jack manufactured in Benton Harbor MI
It is a 12 Ton and it is pretty heavy and stable, I refuse to use the POS jacks from China, The US jack is NOT cheap $200 but why take a chance with China crap if you are on the road and need to change a tire? just my 2 cents |
Re: What kind of jack do you carry Lightweight floor jack, two jack stands, a bottle jack and a 12 in. 2x 6
Re: What kind of jack do you carry I use a crappy old 2 1/2T bottle jack and a couple of scraps of 2X12s. An old broom stick works for a handle. No rocket science here. Be sure to loosen the lug nuts before lifting and you’re good.
Re: What kind of jack do you carry Duplicate
Re: What kind of jack do you carry If you use the scissors jack on the frame before the rear axle you can get the vehicle pretty high up. I have a 1949 and the rear fender covers that top of the tire. On the front, use the scissors jack on the frame behind the wheel. Dont forget the wedge to chock the wheels so the vehicle doesnt roll.
Re: What kind of jack do you carry I use a bottle jack that came from an old Ford Econoline van along with a piece of 2x10. I do have the original bumper jack but don't use it.
Re: What kind of jack do you carry The best invention ever. Many years ago I bought a 41 2dr & this was in the trunk. So simple take any spark plug out screw this some kind on one way valve in the hole. comes
with enough air line with air gauge start engine pump up tire. also has a box wrench for the spark plug. I have never had a flat on the road but mostly got a flat over nite usually a nail. Its gotta be more than 60yrs old perfect shape. I changed too many truck and bus tires when I had good bones no more not even a wheel barrow no more.... |
Re: What kind of jack do you carry big job,
If possible please post a couple of photos of "the best invention" you mentioned in your post above. Does this invention fill the tire with exhaust from the combustion chamber? |
Re: What kind of jack do you carry 3 Attachment(s)
I also carry this home made tire lever that makes it east to remove and lift a tire without straining your back. Made it from a gardening hoe tool.
Re: What kind of jack do you carry Be sure to have a tool that will loosen the lugs; like a breaker bar and 6 point socket.
Holds true for your daily, too. More so if the lugs were tightened by that guy at the tire shop; you know, the one with the heavy trigger finger. |
Re: What kind of jack do you carry I carry and use a hydraulic bottle jack, and a scissors jack. These two jacks cover most anything I need to do for repairs or maintenance on a road trip. I also carry an original '35 Ford jack along with all the original tools for display purposes only during shows.
Re: What kind of jack do you carry Two cans of Fix-A-Flat and a lucky rabbits foot.
Re: What kind of jack do you carry My 46 came with a 36 style jack, used it on that car many times, has the flip top that fits the rear tube curve so it can't slip off, the 3 piece handle folds good, and is long enough to push the jack into position, it's the one I have for the 36 too
Re: What kind of jack do you carry I like your "tire lever" Jim!
I carry a fairly heavy duty scissors jack and a piece or 2" X 8" as a platform on the ground. Jack under the axle otherwise you have a very extended and dangerously wobbly situation. Glenn |
Re: What kind of jack do you carry I am talking a non stock vehicle here. I have been carrying the cheap floor hack from HF and a jack stand. I even carry a battery operated tire gun all to make life easier. I recently bought a small rv and their scissor jacks are 2.5 ton each and go pretty high. So, I will switch over to that scissor jack, chock my wheels, retain the jack stand for insurance and the tire gun to raise and lower the scissor jack, and a couple small pieces of 2x6. If your car is low like most of mine are, the rv scissor jack (and others) are pretty flat.
Re: What kind of jack do you carry Besides the Jack Daniels, in my 48 I have a scissors jack out of an old Honda. For the other cars, I have AAA towing insurance.
Re: What kind of jack do you carry I have an inexpensive scissor jack. You should be able to get the jack under the axle and you only need to lift the tire 1/2" off the ground. If the vehicle is not severely lowered you should be able to get the wheel and tire off and the spare on.
Most important, make sure you test your equipment. make sure you can get the hubcap off. Make sure you can undo the lugnuts. make sure you can chock the wheels. Make sure you have something to put under the jack if not on solid ground. Go through an exercise of changing one front and one rear wheel. Do this in ideal circumstances and then make sure you stow all that equipment in the car. If you ever need it out on the road then you can have some confidence you should be able to do what you need to do. If you just get a jack that someone recommended you might be in trouble if you come to use it and it isn't suitable or you can't get the nuts undone. I had the tires changed on my daily and some time later I wanted to change a wheel and I broke the wheelbrace (lugwrench) that came with the car. The nuts were so tight I couldn't undo them. I had to loosen all the wheelnuts and torque them properly. I then repaired the wheelbrace and made sure it could undo the properly tightened nuts. Hence the advice to test what you decide to use. Mart. |
Re: What kind of jack do you carry cell phone to call a rollback, and a credit card to pay for it and the tire repair. no room in the avatar for a spare or jack.
Re: What kind of jack do you carry Sometimes I'll invite my buddy John along. We shorten his name to Jack...
Re: What kind of jack do you carry Sometimes I invite my friend John along but he prefers Jack!
Now if I get tires, when I come home, I use my air ratchet to loosen all the lug nuts and re torque them so that I can replace the tire if need be. I even tore a bicep once trying to loosen an over tight lug nut...now that was just over the top! |
What's a good number to torque them to for safety AND removal? |
Re: What kind of jack do you carry Small floor jack that came in a case and some wooden blocks.
I have no clue. As far as getting a mix from compression I imagine it does, but you are only pumping the tire which has to be fixed anyway to get home. They sold many of these. There is no makers name so I don't even know what you call it. As far as its date, I say this was from the flatheads all cars not for this new stuff where you can't even find the plugs never mind gettin them out. The thing for the spark plug hole is 14mm so that rules out Model A's and T's and not for GMs stupid peanut plugs..... |
Re: What kind of jack do you carry JM and I were in a 36 Ford and got a flat in Bakersfield CA. There was no jack in the car so we borrowed one from a family in a mini van eating lunch. It was not our car so so as an act of good will for the loan we bought him an original jack.
Re: What kind of jack do you carry ... and I'm not even good once as I ever was.:(
Re: What kind of jack do you carry Scissors jack and if that fails cell phone and AAA card.
Re: What kind of jack do you carry I was going to offer AAA but since it's already posted ... I will simply thank this thread for reminding me to include a torque wrench for the lugs. Never crossed my mind and I do have a $20 HF spare. Maybe a rubber mallet for the wheel covers as well.
OK, a well stocked tool chest too and 2 gals of gas and 2 cans of oil. |
Bought one of these from Aldi of all places, that and my Haggerty insurance has roadside assistance.
