Re: Looking for repro FORD script coil 1 Attachment(s)
I have this one if someone needs it. I have no use for it so $50 would be plenty. Just pm me if you can use it. Not sure if it works.
Re: Looking for repro FORD script coil I'll take you coil. Where shall I send payment?
Bullrhider |
Re: Looking for repro FORD script coil I pm'd you the address.
Re: Looking for repro FORD script coil Quote:
https://www.fordbarn.com/forum/attac...6&d=1746145762 I was using a coil like this for a long time, but last week it died - the secondary winding is open. Is there any possible way to repair it? Is that sleeve that holds the top in place soldered on? Or should I just toss it? Doug |
Re: Looking for repro FORD script coil The amount of work to repair a coil is likely way out of proportion to its value. Remember the components are (best case) immersed in oil or (worst case) sealed in hardened epoxy.
Re: Looking for repro FORD script coil Doug, Empty the can and put a new coil inside. Find a new coil that fits inside. I think most of the ones that you can buy from the dealers will fit.
Re: Looking for repro FORD script coil What does the circled SP on the coil represent? I assume a manufacturer?
Re: Looking for repro FORD script coil Ye Olde Standard Products (now Standard Motor Products)
Re: Looking for repro FORD script coil "The originals generally had a permanently attached bracket. " - the one on my car is like this. (March 1928)
Re: Looking for repro FORD script coil Is this repro coil still available?
Re: Looking for repro FORD script coil Is your repro coil still available?
Re: Looking for repro FORD script coil 5 Attachment(s)
I have one that I would also sell for $50 plus postage (probably under $10 in a small box), since that seems to be the going rate for these rare script coils on this website. There are no dents. I don't know if it works, but I have no reason to think it doesn't. $50 as is plus postage, working or not, rain or shine, pretty much cleaned to bare metal.
Marshall |
Re: Looking for repro FORD script coil Most of the original coils I've seen will work when you get started but lose strength quickly as they heat up.
Re: Looking for repro FORD script coil 2X Alex.
