Re: 2013 Moonshine Festival Ken, I think of you and Barb daily. You have had a rough year. God Bless the both of you! Looking forward to see you guys in Gettysburg next June. Pat
Re: 2013 Moonshine Festival Thanks,John for the pictures,It was a very good meet lots of old fords to enjoy.
Re: 2013 Moonshine Festival Hey Vic,
This is Mike Sydney from Homosassa. We met in Dawsonville. My 40 Flatty is acting like it is starving for gas when I get over 50mph. Carb seems to have plenty of fuel. Got any ideas? Fuel pump? Fuel line? Air leak? Mike |
Re: 2013 Moonshine Festival Hi Mike, Your description of the problem could be attributed to any and all of the things you mentioned however, I would check for any vacuum leaks and adequate fuel flow from the fuel pump to the carb. Also, check at idle, turn the air/fuel mixture screws one at a time to see if they produce any change in the engine idle. If they do not, that would most likely indicate a bad power valve. If everything with respect to fuel delivery is up to par and the carb adjustments do have an effect, I'd check the timing/distributor, etc. Without actually being there, it's tough to pin down the source(s) of the problem.
Re: 2013 Moonshine Festival Quote:
Have you tried slowly pulling out the choke to see if it goes away ? Also make sure your fuel pump isnt sucking air around the lid if you have a steel bowl fuel pump. If its a glass bowl make sure it isnt sucking air around the top of the glass bowl. |
