Old 02-03-2013, 02:11 PM   #1
john in illinois
john in illinois's Avatar
Default reverse eye spring
Hi, I am new to the forum. I am starting an A v8 roadster with a 59A flathead. I need a front28-34 reverse eye spring with 3/4" eyes to match spring perch. Model A has smaller shackle bushings. I can buy a new reversed main leaf with 3/4" eyes but I also have to buy a new standard spring to put it on. I do not want a Posie or easy slide spring.
Does anyone sell a complete reversed standard spring?
Thanks,John
Last edited by john in illinois; 02-03-2013 at 02:19 PM. Reason: change wording, add word
john in illinois is offline   Reply With Quote
Old 02-03-2013, 02:18 PM   #2
Bassman/NZ
Bassman/NZ's Avatar
Default Re: reverse eye spring
Originally Posted by john in illinois View Post
I need a 28-34 reverse eye spring with 3/4" eyes to match spring perch. Model A has smaller shackle bushings. I can buy a new reversed main leaf with 3/4" eyes but I also have to buy a new standard spring to put it on. I do not want a Posie or easy slide spring.
Thanks,John
You can do it yourself. Mark your spring on the garage floor with chalk. Then mark across the leaf at 2" intervals. Beat on those intervals with a BIG hammer and hit it until it is reversed and the same shape as your chalk mark on the floor. Another way is to use a bottle jack and press it into the reverse shape. A bit easier on the ears too. It takes a couple of hours to do, each hit or press will move it a little, so patience is required. I did mine, works fine.
Bassman/NZ is offline   Reply With Quote
Old 02-03-2013, 02:33 PM   #3
42guy
42guy's Avatar
I had a new main leaf made at truck spring shop. Cost about $60. Took old one and told them to make same arch but reverse eye.
42guy is offline   Reply With Quote
Old 02-03-2013, 04:44 PM   #4
Torchie
If you go over to our sister site The HAMB you can search for many threads showing exactly how to do this. Not hard to do especialy if you have access to a press of some kind. But as stated you can do it with a dead blow and some blocks. Wear ear and eye protection.
The HAMB is also a great place for info on building an A-V8 trditional stlye car.
Torchie is offline   Reply With Quote
Old 02-03-2013, 06:56 PM   #5
john in illinois
Thank you for the information. I will check HAMB.I am a new member there also.
John
