Old 08-15-2012, 07:50 PM   #1
BOSSY
BOSSY's Avatar
Default 64 Fairlane gas gauge
What can be wrong with my gas gauge in a 64 Fairlane T-Bolt clone. New tank and sender and Gauge voltage regulator on gauges. When you turn key on the gauge goes to half full if you lift the float it goes past full so I bent the float arm and it does the same thing? Now I bought a new sender and this one does the same thing? I even tried another 64 Fairlane gauge and a new gauge voltage regulator and it does the same thing??????? What could I be missing? Thanks Ron. rrbedard@charter.net
BOSSY
BOSSY is offline   Reply With Quote
Old 08-15-2012, 08:03 PM   #2
rick55
rick55's Avatar
Default Re: 64 Fairlane gas gauge
Just make sure you have an earth (ground) wire on the tank sender to the chassis. Sounds like your fuel gauge is trying to earth through the temp gauge circuit.
If this is not the problem from your description it could also be that your float arm is fouling on something in the tank.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 08-16-2012, 07:03 AM   #3
BOSSY
BOSSY's Avatar
Rick I have a ground from tank to frame and have tried with ground from the sender unit and it is still the same? Thanks for your reply. Ron.
BOSSY
Old 08-16-2012, 09:23 PM   #4
Dominic Hide
If the gauge works through its range out of the tank, and the float is not half full of gas, then I would suspect that the arm is too long and the float is hitting the underside of the tank.
Dominic Hide is offline   Reply With Quote
Thread Tools
Display Modes
