#1 |
will 58 f 100 front brake and hub assemblies fit 53-56 f 100 spindles ?
#2 |
I have been told that up to 64 will work-should be easy to check out. I also know from experience that 77 bronco 2's are the same
#3 |
I believe that 57 thru 64 will work for the 58. 48-56 are the same. I think all that is different would be the inner race and bearing.
#4 |
The backing plates and hubs do not fit the earlier spindles. The bolt pattern on the plates is different, the bearings are different both in size and spacing.
The shoes, wheel cylinders, springs, and drums will interchange. |
| Thread Tools | Search this Thread |
| Display Modes | |
