Old 05-04-2012, 01:33 PM   #1
mrroosky
Default 1928 Model A wiring schematic
Any body out there have a full page of the wiring that is printable?
I found one from an earlier post but it so small that it is not readable.
I tried to zoom in on it, but that didn't help either.
Thanks,
Harry
mrroosky is offline   Reply With Quote
Old 05-04-2012, 01:46 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: 1928 Model A wiring schematic
Here is the one I post often,
Old 05-04-2012, 01:55 PM   #3
d.j. moordigian
d.j. moordigian's Avatar
Mike,
That mite not be correct for his "28".....depending on what is on his car.
d.j. moordigian is offline   Reply With Quote
Old 05-04-2012, 02:22 PM   #4
mrroosky
Smile Re: 1928 Model A wiring schematic
Thanks Mike,
Now to get it shrunk to fit on one page.......my problem.
Harry
Old 05-04-2012, 03:46 PM   #5
30Ford
Is the red wire coming off the ignition switch go on the negative or the positive side of the coil
TKS
30Ford is offline   Reply With Quote
Old 05-04-2012, 05:01 PM   #6
wrndln
Dudley is correct, the diagram posted above is for the later 2 bulb systems, not the cars with single bulb headlights. Note there is a DIM on the diagram which 28 don't have. They only have BRIGHT and PARK. 28's only have 2 positions for the light switch besides OFF. Later A's have 3 positions besides OFF. Hope this helps.
Rusty Nelson
Old 05-04-2012, 06:05 PM   #7
1931 flamingo
1931 flamingo's Avatar
Something is probably better than nothing...................
paul in CT
Old 05-04-2012, 06:20 PM   #8
d.j. moordigian
There is a BIG difference....
Harry...inside your "light switch", is there 3 or 4 brass contacts, that turn with
the horn/light rod? You need to know this 1st.
Old 05-04-2012, 08:30 PM   #9
RUNNERBUN
RUNNERBUN's Avatar
mrroosk, if you wish to print the picture on one page just do the following. Hover your curser over the picture and do a right click on your mouse. A dialog box will appear. from this dialog box click "save picture as" and choose a location to save it to on your computer. then open the file on your computer and print the picture as a normal photo. You should be able to print picture in any standard photo size or A4. Trust this helps
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is online now   Reply With Quote
Thread Tools
Display Modes
